Author Topic: Nordost,Cardas,Kimber,MIT, spk cable,I/C, PC electrical properties (L,C,R)  (Read 42863 times)
jb
  • Global Moderator
  • Sr. Member
Recently purchased this Eucol U2817A industrial grade LCR meter, and able to measure resistance of 0.00001 Ohm to 99.9 Mohm , Capacitance 0.00001pF to 99.9 mF and inductance of 0.00001 uH to 99.9 kH  at frequency of 50 Hz to 100Khz.
Will start using the LCR meter to start measure some branded speaker , interconnect and power cord and archive the brand and cable test results on this thread. Any bro that have expensive cable that want it to be measure can PM me privately and later test results publish here. Hopefully we can see a measurement trend on why some branded cable has great performance... also I will be using the LCR meter to design speaker crossover circuit for inductor coil.
« Last Edit: July 15, 2017, 10:07:30 PM by jb »
WildRain
  • Freshman member
bro....looking forward to your results  :+1:
Sony Z1es | Densen DM20 | DM30 | Dynaudio S1.4
Nordost Heimdall | Baldur | QED Genesis
Maestro | 7N-4030 | Plixir Elementa BAC3000 | PC
jb
  • Global Moderator
  • Sr. Member
I will received the LCR meter within next two weeks and will start publish some high end brand cable test results... Let me know if you have any great cable that you want me measure and publish here.
jb
  • Global Moderator
  • Sr. Member
Re: Nordost,Cardas,Kimber,MIT, spk cable,I/C, PC electrical properties (L,C,R)
« Reply #3 on: December 09, 2016, 09:29:28 PM »
Finally the LCR meter is here! will start doing some measurement for Nordost cable and archive the test results here..any forumer want to have their cable tested can PM me.
« Last Edit: July 16, 2017, 09:27:36 AM by jb »
collins
  • Newbie
« Reply #4 on: December 09, 2016, 10:19:04 PM »
Need to pay test fee or not? ;D
jb
  • Global Moderator
  • Sr. Member
« Reply #5 on: December 09, 2016, 10:36:00 PM »
haha, I hope I don't have to pay fee for them to bring cable for me to test! ;D
Francis Huang
  • Freshman member
« Reply #6 on: December 11, 2016, 10:00:27 PM »
Will you still be doing testing in jan?
Prob can only bring my cables to u ard jan, as i have visitors this few weeks. It will take abt 1 week for the sound to return to normal of i unplug it.
jb
  • Global Moderator
  • Sr. Member
« Reply #7 on: December 11, 2016, 10:37:01 PM »
No worry, as I will continue to test various branded cable. You can bring to me in Jan for testing.
Francis Huang
  • Freshman member
« Reply #8 on: December 12, 2016, 12:21:46 AM »
Am using nordost. Which nordost model is slated for testing?
jb
  • Global Moderator
  • Sr. Member
« Reply #9 on: December 12, 2016, 10:43:06 AM »
So far I have slotted for measurement:
Nordost :
blue heaven I/C
Blue heaven speaker cable
Blue heaven power cord
red dawn I/C
Hemidall speaker cable
Frey I/C
anyway, the cable measurement only take few minutes for each cable as need hand record down the reading, in future I will automate the measurement using laptop so each cable will only take few sceond.
Francis Huang
  • Freshman member
« Reply #10 on: December 12, 2016, 12:36:59 PM »
Noted
I will bring the power cords from the rest of the range
Wizardofoz
  • Global Moderator
  • Jr. Member
« Reply #11 on: December 12, 2016, 12:42:03 PM »
I can probably chip in the odd Belden too at some stage timing permitting, might bring the Fluke LCR along for the comparison too.
jb
  • Global Moderator
  • Sr. Member
« Reply #12 on: December 12, 2016, 12:56:48 PM »
No problem... just let me know in advance, so as able to arrange the timing schedule.
jb
  • Global Moderator
  • Sr. Member
« Reply #13 on: December 14, 2016, 12:09:42 AM »
Just do a quick measurement of the Nordost speaker cable:
Blue heaven:
Freq = 1Khz , L=3.3uH , R=0.06 Ohm ,  when speaker wire coil together and measured as  L=11uH , R=0.06 Ohm
Heimdall:
freq = 1 Khz, L=3.55uH , R=0.04 Ohm
From this measurement , it can be concluded that higher tier cable of same brand  the resistance will be lower, and don't laugh at some user that use clip to float the cable in air, as by doing so they just reduce the self inductance of the speaker cable. But actually all u need to do is just lay the cable straight so that it does not cross and the cable inductance will reduced. Also as the cable resistance is extremely low, it makes sense to have the speaker contact clean properly and remove the oxidation so u get the best low resistance contact.
« Last Edit: December 14, 2016, 12:26:50 AM by jb »
jb
  • Global Moderator
  • Sr. Member
« Reply #14 on: December 15, 2016, 11:56:10 AM »
some Nordost cable electrical parameter measurement test results as attached. please noted some speaker cable the resistance is extreme low, so use a good contact solution to clean and make sure you have solid low resistance to get the full benefit of the cable.
